Mini-USB
Plaats hier alles over schaalmodellen & speelgoed
Mini-USB
Berichtdoor Wally » Do Nov 23, 2006 20:06
Vond deze ergens op internet. Iemand een idee of dit te koop is
of zou de eigenaar hiervan zelf wat hebben geknutseld :?:
Berichtdoor Morty » Do Nov 23, 2006 20:10
dat is zelf geknutseld, maar ik heb daar de howto eens van teruggevonden.
Weet alleen niet meer waar en hoe.
Zal eens zoeken.
Berichtdoor Wally » Do Nov 23, 2006 20:52
Gevonden :grin:
This Mini sure does drive...no pun intended. It's a USB Flash Drive built
into a Hot Wheels model of a Mini Cooper. I saw some various mods
using USB drives, such as a PEZ and Lego drives. I think I remember
reading something about someone who made a drive fit into a Hot Wheels
car, but I don't remember where. I saw this Mini sitting on my shelf, and
figured, hey, I'm never gonna use it for anything anyways, so I might as
well put it to use. This was really pretty easy to make, and I didn't plan
out one bit of it, so there's not really a good how-to. I will explain how I
did it, though. First, I drilled out the rivets that hold the bottom of the car
to the body with a drill press. Once those were out, I separated the two
and *** off the front end with a Dremel and cutting wheel attachment.
I then *** the bottom piece in two, in line with the first body ***. I had
decided to use the cap that came with the drive in the mod somehow,
because it makes a nice friction fit with the USB plug, so I could be sure
the front end wouldn't fall off. I ground down the cap as small as possible
without ruining it and slid it into the cut-off front end. The car needed some
modding as well, because there were various structural supports that
prevented the cap from fitting in. I just ground down all the extra pieces
of metal sticking out so the car was completely hollow. Once the cap was
glued in with hot glue, I could move on to the drive case. This part was
probably the easiest, as all I had to do was glue a bit of balsa wood the
correct thickness to support the USB drive. Then I glued the drive to the
wood, and re-glued the body onto the bottom piece. Finally, I *** out some
foam that was left over from my iPod dock to put over the opening to hide
the interior workings. I also *** some plastic from a clear report or paper cover
and covered the top of the circuit board with it to prevent dust from getting in.
Berichtdoor Morty » Do Nov 23, 2006 20:57
als ge u bereidt voelt ;)
Berichtdoor eriks » Do Nov 23, 2006 21:39
leuk ding , zou mij ook wel bekoren :D :wink:
Berichtdoor fred » Do Nov 23, 2006 21:43
Mooi gedaan :)
Racing Green
Berichtdoor Racing Green » Zo Jul 13, 2008 17:37
Berichtdoor koemans » Wo Feb 25, 2009 18:36
haha zo iets zou ik ook wel willen
Racing Green
Berichtdoor Racing Green » Za Okt 17, 2009 13:10
De classic kan ik leveren, in alle kleuren op de foto, met of zonder bonnet stripes.
19€ voor 4G, 25€ voor 8G, en ze zitten in een zwarte giftbox, leuk voor de kerst.
Mailtje naar vanreusel.bart@gmail.com bij intresse.
BlackBoxGirl
Berichtdoor BlackBoxGirl » Di Okt 20, 2009 10:40
Hey, moest er iemand interesse hebben, er bestaan nu ook USB sticks in de vorm van een nieuwe MINI sleutel! ( R 55, R 56, R 57 ) en dit met 8 GB. Voor prijs doe even pm!
groetjes,
BBG
Racing Green
Berichtdoor Racing Green » Wo Dec 15, 2010 20:34
Ook new mini's met de stick uit de koffer zijn intussen op de markt.
En de classics, die heb ik nog altijd in de aanbieding, in zo'n 15-tal variaties.
Terug naar “Mini MINI”
Gebruikers op dit forum: Geen geregistreerde gebruikers en 22 gasten
