Terugroepactie Cooper S en JCW 2009-2011
Berichtdoor varavital » Zo Jan 15, 2012 18:16
Terugroepactie aangekondigd in Amerika voor waterpompen op de Cooper S en JCW modellen van 2009-2011 met de N14 motor.
Heeft er hier iemand weet van wanneer deze actie in Europa op touw gezet zou worden? Aangezien de MINI's allemaal uit dezelfde fabriek komen...
The Issue
The issue involves the electric auxiliary water pump on models that are equipped with the N14 turbo engine. The auxiliary pump is controlled electronically by an engine control unit. After switching off the engine, the electric auxiliary water pump conducts heat away from the turbocharger.
Under certain conditions, the pump’s electronic circuit board can malfunction. The malfunction can occur as a result of certain design features in combination with high operating temperatures.
If the water pump can fails, there’s a slight chance that the circuit board can overheat. And in an extreme case, overheating of the circuit board can lead to smoldering of the water pump. If smoldering occurs, this may also lead to an engine compartment or vehicle fire.
Models Affected
Here’s the full list of Cooper S models affected:
2007-11 / Cooper S (Dec 2006 – Oct 2010)
2008-11 / Cooper S Clubman (Dec 2007 – Oct 2010)
2009-11 / Cooper S Convertible (Dec 2008 – Oct 2010)
2009-11 / John Cooper Works (JCW) (Jun 2008 – Oct 2010)
2009-11 / John Cooper Works (JCW) Clubman (Jun 2008 – Oct 2010)
2009-11 / John Cooper Works (JCW) Convertible (Apr 2009 – Oct 2010)
2011 / Cooper S Countryman (Nov 2010 – Jan 2011)
How can you tell if this is happening to your MINI? The first tip-off will be a plastic burning smell, or burning and/or smoke from the front of the vehicle may be noticed.
Berichtdoor Suz works » Ma Jan 16, 2012 11:07
Ik heb ze nog niet horen roepen.... :D
petit_cru
Berichtdoor petit_cru » Ma Jan 16, 2012 13:17
Op de redactie.be volgend artikel gelezen:
ma 16/01/2012 - 12:09
De Duitse autoconstructeur BMW roept 235.000 Mini's terug wegens problemen met de waterpomp, waardoor er brandgevaar zou kunnen optreden. Het gaat om de modellen Mini Cooper S en Mini John Cooper Works die tussen maart 2006 en januari 2011 geproduceerd werden. In België worden 2.000 wagens teruggeroepen, laat BMW Belux weten. De betrokken eigenaars krijgen een brief. De waterpomp wordt gratis vervangen.
Berichtdoor Suz works » Ma Jan 16, 2012 13:39
Allez vooruit... :D
en binnenkort een terugroepactie voor de Countryman SD ... de zogezegde "chromé"
die begint af te pellen van de raamlijsten...
Berichtdoor schumi » Ma Jan 16, 2012 17:13
Berichtdoor PEPI » Ma Jan 16, 2012 22:16
Ik moet met beide wagens binnen :shock:
Berichtdoor sscooper » Di Jan 17, 2012 10:37
sebiet is ff tel plegen want dat vind ik ni echt leuk die gedachte :( iemand al brief ontvangen van MINI? ik ga er niet op wachten in ieder geval :twisted: :?
YorkPower
Berichtdoor YorkPower » Di Jan 17, 2012 12:04
sscooper schreef:sebiet is ff tel plegen want dat vind ik ni echt leuk die gedachte :( iemand al brief ontvangen van MINI? ik ga er niet op wachten in ieder geval :twisted: :?
Gezien er slechts zeer bepekte last van is geweest tot nu toe moet je niet meteen vrezen dat hij stuk gaat :). Het is uit voorzorg, zou even goed kunnen dat je nog 20 jaar lang blijft rijden zonder dat er iets fout gaat.
Als er nu 2000 man gaat bellen zullen ze nog wat extra werk hebben ;) :grin:
Berichtdoor PEPI » Di Jan 17, 2012 13:49
De beller is sneller :)
Ze moeten iedere eigenaar van de wagen die hier betrekking op heeft verwittigen en vragen of hij contact opneemt met de concessie... Achteraf bellen die eigenaars dan toch terug. Dus best in één keer zelf bellen en afspraak maken. Zo is het in één keer gefixt ;)
Berichtdoor varavital » Di Jan 17, 2012 17:45
Wacht gewoon af als je een brief krijgt van MINI belux of niet. Ze zullen zeker niemand overslaan, de lijsten worden normaal gewoon opgevraagd bij de DIV (is verplicht voor een recall campagne).
Dus niet zelf gaan zitten bellen, is gewoon overlast veroorzaken voor de dealers en die zullen allicht toch gewoon zeggen dat je moet wachten op de brief. Ik weet waarvan ik spreek, krijg ook dikwijls zo'n telefoontjes van ongeruste klanten terwijl het niet nodig is...
Berichtdoor Dangixxer » Di Jan 17, 2012 18:19
varavital schreef:Wacht gewoon af als je een brief krijgt van MINI belux of niet. Ze zullen zeker niemand overslaan, de lijsten worden normaal gewoon opgevraagd bij de DIV (is verplicht voor een recall campagne).
Zijn er bij Onda dan "recalls"? :wink:
Da ding werkt toch altijd :D
idd wachten en iedereen zal wel gecontacteerd worden
En de getunende MINI's gewoon opletten dat ze niet te hevig van "jetje" geven :o
Berichtdoor varavital » Di Jan 17, 2012 21:36
Dangixxer schreef:Zijn er bij Onda dan "recalls"? :wink:
Stuur mij uwe chassisnummer eens, zal eens kijken als er nog iets open staat :wink: .
Chico
Berichtdoor Chico » Do Jan 19, 2012 19:23
Ik heb een cooper s r56 gekocht (2dehands)
Ze hebben direct al de waterpomp aangepast !
Nu nog wachtn op een attest voor de kw veering en keuren !
Kan niet wachten :grin: !!!
frankie
Berichtdoor frankie » Ma Jan 30, 2012 20:36
Ik weet niet hoe het in België is, maar in Nederland zijn er voorlopige nog geen aangepaste waterpompen op stock en is ook onduidelijk wanneer dit wel is.
Ik heb trouwens van de Duitse dealer waar ik mijn Clubbie gekocht heb een brief gekregen om een afspraak te maken voor vervanging. :roll:
Berichtdoor conrad » Di Jan 31, 2012 21:25
Ik mag de mijne morgen al binnendoen :grin:
Crazywhite
Berichtdoor Crazywhite » Di Jan 31, 2012 23:18
die van mij zit er ook bij.
ik mag 25 februari binnen vanwege back order in Duitsland.
Berichtdoor sscooper » Wo Feb 01, 2012 0:12
conrad schreef:Ik mag de mijne morgen al binnendoen :grin:
doe je hem binnen waar hij gekocht is of bij u in de buurt? grtz
Berichtdoor MY Dweiltje » Wo Feb 01, 2012 14:30
zijn ze snel deze keer in't oosten van't vlaamse land
Berichtdoor conrad » Wo Feb 01, 2012 17:50
Hey Steven,
Ik ben in Hasselt geweest. Zij hadden mij ook opgebeld voor deze afspraak.
Berichtdoor varavital » Vr Mar 02, 2012 16:33
Ze hebben mij ook gebeld, de mijne mag deze maand ook binnen voor die terugroepactie.
