Terugroepactie Cooper S en JCW 2009-2011
Geplaatst: Zo Jan 15, 2012 18:16
Terugroepactie aangekondigd in Amerika voor waterpompen op de Cooper S en JCW modellen van 2009-2011 met de N14 motor.
Heeft er hier iemand weet van wanneer deze actie in Europa op touw gezet zou worden? Aangezien de MINI's allemaal uit dezelfde fabriek komen...
The Issue
The issue involves the electric auxiliary water pump on models that are equipped with the N14 turbo engine. The auxiliary pump is controlled electronically by an engine control unit. After switching off the engine, the electric auxiliary water pump conducts heat away from the turbocharger.
Under certain conditions, the pump’s electronic circuit board can malfunction. The malfunction can occur as a result of certain design features in combination with high operating temperatures.
If the water pump can fails, there’s a slight chance that the circuit board can overheat. And in an extreme case, overheating of the circuit board can lead to smoldering of the water pump. If smoldering occurs, this may also lead to an engine compartment or vehicle fire.
Models Affected
Here’s the full list of Cooper S models affected:
2007-11 / Cooper S (Dec 2006 – Oct 2010)
2008-11 / Cooper S Clubman (Dec 2007 – Oct 2010)
2009-11 / Cooper S Convertible (Dec 2008 – Oct 2010)
2009-11 / John Cooper Works (JCW) (Jun 2008 – Oct 2010)
2009-11 / John Cooper Works (JCW) Clubman (Jun 2008 – Oct 2010)
2009-11 / John Cooper Works (JCW) Convertible (Apr 2009 – Oct 2010)
2011 / Cooper S Countryman (Nov 2010 – Jan 2011)
How can you tell if this is happening to your MINI? The first tip-off will be a plastic burning smell, or burning and/or smoke from the front of the vehicle may be noticed.
