Berichtdoor Morty » Vr Jul 27, 2007 13:49
Heb net prijzen binnengekregen.
Prijs ( allen standaard met DSC, airco en alu velgen ):
Clubman Diesel 1.6 (110pk) : 22.600 €
Clubman Benzine 1.6 ( 115pk) : 20.950 €
Clubman Benzine Turbo 1.6 (163pk) : 26.050 €
Hij is in totaal 24cm langer en 8cm bredere wielbasis.
Lengte verschil t.o.v. de standaard MINI
24 centimeters langer, wielbasis en beenruimte achteraan 8 centimeters
bagage 260 tot 930 liter (met achterste stoelen plat)
Market launch in Germany on 10 November 2007 with three engine variants:
MINI Cooper S Clubman:
Four-cylinder gasoline engine with twin-scroll turbocharger and direct fuel injection
Capacity 1,598 cc, max output 128 kW/175 hp at 5,500 rpm, max torque 240 Nm/177 lb-ft at 1,600–5,000 rpm (260 Nm/192 lb-ft with Overboost)
Acceleration (0–100 km/h) in 7.6 seconds - Top speed 224 km/h (139 mph)
Average fuel consumption to EU standard 6.3 litres/100 kilometres
CO2 emissions 150 g/km.
MINI Cooper Clubman:
Four-cylinder gasoline engine with fully variable valve management based on the BMW Group’s VALVETRONIC technology
Capacity 1,598 cc, max output 88 kW/120 hp at 6,000 rpm, max torque 160 Nm/118 lb-ft at 4,250 rpm
Acceleration (0–100 km/h) in 9.8 seconds - Top speed 201 km/h (125 mph),
Average fuel consumption to EU standard 5.5 litres/100 kilometres
MINI Cooper D Clubman:
Four-cylinder turbodiesel with common-rail fuel injection and variable turbine geometry
Capacity 1,560 cc, max output 80 kW/110 hp at 4,000 rpm, max torque 240 Nm/177 lb-ft at 1,750 – 2,000 rpm (260 Nm/192 lb-ft with Overboost)
Acceleration (0–100 km/h) in 10.4 seconds - Top speed 193 km/h (120 mph)
Average fuel consumption to EU standard 4.1 litres/100 kilometres
