Kerstkadootje van Garmin
Firmware update 3.80 is uit Installeren via de webupdater
Changes made from version 3.30 to 3.80:
* Add support for African Time zones.
* Add support for several new pre-recorded voices.
* Add support for distances in yards when a British voice is selected (may require updated voice).
* Added support for MAD Maps scenic routes.
* Allow the compass page to display 5 digits of elevation.
* Improved handling of circular routes. Allows entry at alternate point. Will not announce arrival when starting a route. (All routes will be deleted after update, but can be re-imported from GPX files.)
* Keep the map detail level when go from main map to browse map.
* When reviewing a gas station after pressing the fuel button from main map, the map will now be centered on selected gas station rather than the vehicle.
* Change Optimal Reorder so it does not include the final point when reordering.
* Correct issue where backlight may change if you remain on the backlight adjust page for a period of time.
* Correct issue where backlight may turn off when location is above polar circle.
* Correct issue that would sometimes cause highways to be labeled with the incorrect name.
* Correct issue that would not allow more than a single point to be added to some routes.
* Correct issues when the same map is loaded in two different regions.
* Correct issue when searching for cities on basemap.
* Correct off road transitions in track to route when there is no map coverage.
* Correct issue playing Audible format 4 books.
* Correct distance for mixed routes imported from MapSource
* Correct issue that caused all traffic delays to be 1min when using certain maps.
* Correct issue that prevented TrafficMaster service from being properly named on the unit.
* Correct issue that prevented some very large track log activities from being archived correctly.
* Correct issue where changes to a route would be lost if you press and hold the back button.
* Correct issue that caused MP3?s to be paused for navigation announcements when navigation was set to off and a pre-recorded voice was selected.
Voor Zumo 500 zie hier
http://www8.garmin.com/support/download ... sp?id=1909
Voor Zumo 550 zie hier
http://www8.garmin.com/support/download ... sp?id=1907
Of natuurlijk via de webupdater van GARMIN
Voor Zumo gebruikers
Orgineel : de stem van Santa Claus bij navigatie, surf naar hier dan :
http://www.mypoiworld.com/
Gratis te downloaden
varavital schreef:Weer goeie verbeteringen. Ben wel nog altijd aan het twijfelen tussen de Zumo en de Nuvi 760. Zal iets voor binnen een paar maanden zijn
Hoi,
In grote lijnen is dit hetzelfde toestel ivm navigatiegedeelte
Mocht ik de GPS niet op de motor gebruiken zou ik geen Zumo kopen maar een Nuvi.
De Zumo is waterdicht en heeft een blue tooth verbinding met mijn helm. Maar dat is niet nodig in de auto he...
eriks schreef:Orgineel : de stem van Santa Claus bij navigatie, surf naar hier dan :
Samen met die stem op de Garmin hellemaal in de sfeer..;
RUSOR schreef:In grote lijnen is dit hetzelfde toestel ivm navigatiegedeelte![]()
Daar zeg je het, in grote lijnen... Zit (voorlopig) toch nog redelijk wat verschil op. Belangrijkste verschil dat de kaarten er (nog) niet bijgeleverd zijn om op de pc te zetten. Trackfunctie niet zo uitgebreid. Nog een aantal functies minder uitgebreid. Maar ik wacht af, bij de zumo heeft het ook een tijdje geduurd eer die via updates was zoals ie moest zijn. Ik hoop dat dat met de Nuvi760 ook nog gebeurt, hij is nog maar juist uit, en dat er eventueel een deluxe versie met kaarten en mapsource op cd erbij uitkomt. Eerst binnenkort ook eens CN2008 bekijken. En vooral veel fora over garmin in de gaten houden
